FPGA Intellectual Property
SMPTE 344M ED-SDI
ShlomiI
Hi
Does SDI II Intel® FPGA IP support SMPTE 344M ED-SDI ?
If not , does Intel has a different IP that support ?
SengKok_L_Intel
Regarding your inquiry on the SMPTE 344M (data rate at 540Mbps) support, as I search through the documentation, the existing SDI II IP does not support this standard.
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
