- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi all.
My question is about the interface of SATA/SAS. I use megafunction Stratix V Transceiver Native PHY. I understand that the bus tx_parallel_data[63..0] is used as data bus and the utility bus signals. But unfortunately, I can't understand how divided the address space on the external drive. For example: I want to record 32-bit word at some address 0x10. What should I record in this case, on the bus tx_parallel_data[63..0]?:confused: Can anyone explain the principle of exchange of information with the external drive? Or give an example? I was looking at the V-Series Transceiver PHY IP Core User Guide, but the answer to my question is not found (https://www.altera.com/en_us/pdfs/literature/ug/xcvr_user_guide.pdf). Thank you in advance. Regards, Andrey.Link kopiert
6 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If I understand right, you are asking about SATA protocol. That's beyond physical layer transceiver specifications. "Serial ATA Revision 3.0" is the present standard.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have the same question, can anyone suggest one application note, if it exists, or something similar can help to design Sata protocol?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
FvM,
But if you look on megafunction. How to write data to avalon bus? Do I need to write control words on bus avalon?- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
gabrizio (https://www.alteraforum.com/forum/member.php?u=109439),
If I understand correctly, it is a communications Protocol that SATA. Here is written at a low level bytes of instructions and data bytes. [url]http://www.lttconn.com/res/lttconn/pdres/201005/20100521170123066.pdf (http://www.lttconn.com/res/lttconn/pdres/201005/20100521170123066.pdf) [/URL]- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- gabrizio (https://www.alteraforum.com/forum/member.php?u=109439), If I understand correctly, it is a communications Protocol that SATA. Here is written at a low level bytes of instructions and data bytes. [url]http://www.lttconn.com/res/lttconn/pdres/201005/20100521170123066.pdf (http://www.lttconn.com/res/lttconn/pdres/201005/20100521170123066.pdf) [/URL] --- Quote End --- Thank you zHedgehoGz, I will check the link you sent me.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Thank you zHedgehoGz, I will check the link you sent me. --- Quote End --- Write here if you reach the result please.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
