FPGA Intellectual Property
6669 Discussions
Shared IP - Stack Based Micro + assembler + testbench
I was trying to post this to shared IP forum, but i wont let me? Anyway I hope posting here is ok
This is something I have been working for a little while - a simple 16 bit micro with an assembler, it is stack based so runs forth type code.
The core is around 380LE in a 3C5F256C8 and runs at 87MHz running code.
The top level is a micro+ram+timer+small pio - the micro responds to interrupts from the timer for demo purposes.
Top level compiles to 606LE + 4M9k blocks - and can be cut down to run an a MAX V/ MAX II device probably EPM1270.
Update : More work done on core, testbench etc - new attachment
