FPGA Intellectual Property
6670 Discussions
Simple Socket Server PCS Mode Disabled
JLee25
I am using C10 GX in custom board for TSE IP core.
My configuration is TSE + LVDS.
After download the image, the connection is not work.
From EDS, it prints out "PCS SGMII mode disabled" as attached below.Msg.pngWhere I can find information to debug this?
Please help!
Thank you!
BRs,
Johnson
JLee25
I forgot to mentioned that I am using Quartus 19.2.0 for this build.
BRs,
Johnson
CheePin_C_Intel
Hi Johnson,
Sorry for the delay. Thanks for your clarification. Please allow me some time to further look into it.
CheePin_C_Intel
To ensure we are on the same page, just would like to clarify if you are using HPS TSE IP or if you are using normal FPGA TSE IP? If you are using normal FPGA TSE IP, just wonder if you have had a chance to test enabling the SGMII_ENA register bit. You may refer to section 5.2.5. If_Mode Register (Word Offset 0x14) in the TSE user guide forfurther details.
Thank you.
JLee25
Hi CheePin,
Thank you!
I will check the FPGA TSE IP core mode register as mentioned.
BRs,
Johnson
CheePin_C_Intel
You are most welcome
