Hi, my name is itay.
I have a weird problem with the DSPBA: When I open the demo_AD9578 it compiles and run perfectly. I actually copy the same filter to my own model and I also make sure that all of the inputs are the same format. input is sfix(16)_En(15), coefs are the same, there are 17 symmetrical coefs (exactly the same as the demo), valid is boolean, ch is uint8, FPGA is stratix IV. When I run my model it doesn't compile and gives me the next error: "Found a non-synthesizable block in the synthesizable block" and points to the Single_Rate_Fir. What can be wrong? I am a bit frustrated about it, cause i am working on it for several days. thanks ahead, Itay.Link Copied
If you attach your model here, it will be much easier to see what's wrong.
From your description, everything seems fine.
