FPGA Intellectual Property
6462 Discussions
Some questions in FIFO IPcore, I use the EP4CE55F23I7
HI i have some question...In my project, I use fifo ipcore, when I use the depth of 8192,4096 or 2048, the data I read is correct, but after increasing the depth, such as 32768,65536 or bigger, the data read out is wrong, it is almost wrong. I use signaltap ii analysis, data is right to write , but not to read.....10bit fifo. and FPGA is Cyclone IV EP4CE55F23I7.....waiting for your reply. thanks
Is the same issue observed in Modelsim simulation?
Thanks for your reply.....I solved the problem by using the logiclock to lock the fifo memory. Thanks a lot
Did the design have any timing failures reported in timequest?
