I am using Stratix 10 SoC Dev kit for high speed communication PoC. The communication link must negotiate to either 10G or 20Gbps link rate. If I see the Native PHY for Stratix 10, I need to use GX XCVR type for 10Gbps and GXT XCVR type for 20Gbps. My question is whether I can achieve the 10Gbps and 20gbps functionality in a single binary with the help of Dynamic reconfiguration block? If Yes, please guide me the procedure to configure the Dynamic reconfiguration profiles by changing XCVR types to GX and GXT.
With Regards,
HPB
Hi Chee Pi,
Thank you for your explanation and I am considering simulation as well.
Further, I was going through Stratix 10 XCVR user guide and found "6.9.3. Reconfiguring Between GX and GXT Channels". Going through the same chapter now.
With Regards,
HPB
I was reading "6.9.3. Reconfiguring Between GX and GXT Channels" and found below statement.
"Dynamic reconfiguration between GX and GXT datarates will be supported in a future Intel Quartus Prime Pro Edition release."
Although, now I am able to configure 2 dynamic reconfiguration profiles with 10gbps(GX data rate) and 20Gbps (GXT data rate) in the Platform designer /qsys and able to generate HDL, above statement is creating some doubts.
With Regards,
HPB
Thank you @cheepinc_Intel for getting the clarification from factory. I am using Quartus 18.1 pro.
With Regards,
HPB
