FPGA Intellectual Property
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
6064 Discussions
Stratix IV M9K blocks usage through DSP Builder
I want to utilize the M9K blocks of Stratix IV FPGA in True Dual Port mode.
Can anyone please let me know how to use them through the DSP Builder?
Suresh
--- Quote Start ---
Suresh
--- Quote End ---
DualMem block infers dual ram.
The use of M9ks is inferred if size is more than the threshold value set in control block(register/mem threshold)
Thanks Kaz for your reply.
I am new to DSP Builder.
Whether the Threshold set in Control Block will not apply to all the blocks used in the design?
I want to use M9Ks and also MLABs in my design. Can I do it?
--- Quote Start ---
--- Quote End ---
The control block is used at project level(I am not aware if it can be used per subsystem). So it applies to all blocks but your thresholds should help give you some control.
There are 4 thresholds:
register/memory (e.g shift registers implemented as registers or in memory)
small ram/medium ram (mluts <=> block ram)
medium ram/large ram (M9Ks <=> larger ram if applicable)
multipliers (logic <=> dsp blocks)
See control block help how to set these.
