FPGA Intellectual Property
6669 Discussions
Support logic conflicts with F-tile PMA clocking and double-width 16b (Quartus Pro 22.1)
alexislms
Valued Contributor I
I tried to set the F-tile:
  • PMA Direct
  • PMA clocking
  • PMA width 16b
  • TX and RX double-width enabled
Qsys doesn't complain and I can generate the files.
From the user guide, it seems possible:
At the Logic generation, I get errors.
Error(21843): Conflict 0 ----------------------------------------------------------------
Error(21843): Rule: gdr_wrapper::topology_mapping_mux_rule @
Error(21843):     as.sw_topology != UX16E400GPTP_XX_DISABLED_XX_DISABLED || gdr.z1577a.topology == UX16E400GPTP_XX_DISABLED_XX_DISABLED
Error(21843): Rule: gdr_virtual_channel::topo_and_stream_down_to_maib_adapter_tx_and_rx_fifo_mode_and_width_rules @ gdr
Error(21843):     gdr.z1577a.topology != UX16E400GPTP_XX_DISABLED_XX_DISABLED || gdr.z1577a.u_e400g_top.e400g_stream15_tx_en == FALSE || gdr.z1577a.u_e400g_top.e400g_stream15_sys_clk_src != E400G_STREAM15_SYS_CLK_SRC_XCVR || gdr.z1577a.u_e400g_top.e400g_stream15_tx_aib_if_fifo_mode != E400G_STREAM15_TX_AIB_IF_FIFO_MODE_REGISTER || gdr.z1577a.u_e400g_top.e400g_stream15_tx_excvr_if_fifo_mode != E400G_STREAM15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP || gdr.z1577a.u_e400g_top.e400g_stream15_tx_primary_use != E400G_STREAM15_TX_PRIMARY_USE_DIRECT_BUNDLE || gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width inside {E400G_STREAM15_TX_XCVR_WIDTH_10,E400G_STREAM15_TX_XCVR_WIDTH_20,E400G_STREAM15_TX_XCVR_WIDTH_32}
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_sys_clk_src_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_sys_clk_src -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_rx[0].rx_ehip.x_bb_f_ehip_rx.sys_clk_src) != E400G_25G_15_SYS_CLK_SRC_XCVR || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en) == FALSE || gdr.z1577a.u_e400g_top.e400g_stream15_sys_clk_src== E400G_STREAM15_SYS_CLK_SRC_XCVR
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_tx_aib_if_fifo_mode_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en) == FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_aib_if_fifo_mode -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_aib_if_fifo_mode) != E400G_25G_15_TX_AIB_IF_FIFO_MODE_REGISTER || gdr.z1577a.u_e400g_top.e400g_stream15_tx_aib_if_fifo_mode == E400G_STREAM15_TX_AIB_IF_FIFO_MODE_REGISTER
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_tx_enable_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_primary_use -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_primary_use) == E400G_25G_15_TX_PRIMARY_USE_DISABLED || gdr.z1577a.u_e400g_top.e400g_stream15_tx_en == TRUE
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_tx_excvr_if_fifo_mode_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en) == FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_excvr_if_fifo_mode -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_excvr_if_fifo_mode) != E400G_25G_15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP || gdr.z1577a.u_e400g_top.e400g_stream15_tx_excvr_if_fifo_mode == E400G_STREAM15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_tx_primary_use_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en) == FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_primary_use -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_primary_use) != E400G_25G_15_TX_PRIMARY_USE_DIRECT_BUNDLE || gdr.z1577a.u_e400g_top.e400g_stream15_tx_primary_use == E400G_STREAM15_TX_PRIMARY_USE_DIRECT_BUNDLE
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_tx_xcvr_width_rule @ gdr.z1577a.u_e400g_top
Error(21843):     (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en) == FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_xcvr_width -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_xcvr_width) != E400G_25G_15_TX_XCVR_WIDTH_16 || gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width == E400G_STREAM15_TX_XCVR_WIDTH_16
Error(21843): Input variables:
Error(21843):     as.sw_topology == UX16E400GPTP_XX_DISABLED_XX_DISABLED
Error(21843):     user.bb_f_ehip_tx[0] -> MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx
Error(21843):         is_used == TRUE
Error(21843):         location == E400G_25G_15
Error(21843):         sys_clk_src== SYS_CLK_SRC_XCVR
Error(21843):         tx_aib_if_fifo_mode == TX_AIB_IF_FIFO_MODE_REGISTER
Error(21843):         tx_en == TRUE
Error(21843):         tx_excvr_if_fifo_mode == TX_EXCVR_IF_FIFO_MODE_PHASECOMP
Error(21843):         tx_primary_use == TX_PRIMARY_USE_DIRECT_BUNDLE
Error(21843):         tx_xcvr_width == TX_XCVR_WIDTH_16
The problem is gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width inside {E400G_STREAM15_TX_XCVR_WIDTH_10,E400G_STREAM15_TX_XCVR_WIDTH_20,E400G_STREAM15_TX_XCVR_WIDTH_32
tx_xcvr_width == TX_XCVR_WIDTH_16 doesn't seem to  be allowed.
Quartus Pro 22.1 and please find attached the ip file.
Is it a bug?
alexislms
As per the user guide, actually it seems 16b isn't allowed for double-width. (also 10b even though the support logic would accept it)
Kshitij_Intel
Can you please share your .qar.
Thank you
Kshitij Goel
alexislms
Hi @Kshitij_Intel ,
The IP is in my first message, could you confirm the IP's configuration is allowed.
Kshitij_Intel
This is only IP, can you please the complete project(.qar) to reproduce the issue.
Thank you
Kshitij Goel
alexislms
Please confirm the IP is valid and that the settings are allowed.
alexislms
Find attached the qar of the project.
Kshitij_Intel
You can change the width to 32 from 16 in the F-Tile PMA/FEC Direct PHY Intel FPGA IP and then it will get compiled. Sharing the screenshot.
Thank you
Kshitij Goel
Kshitij_Intel
Have you tried with changing the width to 32, It should be able to compile.
Thank you
Kshitij_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you
Kshitij Goel
