Can any of you see if i have done something stupid below: I cannot transmit anyhing. First my setup code: alt_tse_phy_profile MV88E1116R = {"Marvell 88E1116R", // MV88E1111_OUI, // OUI 0x24, // Vender Model Number 0, // Model Revision Number 0x11, // Location of Status Register 14, // Location of Speed Status 13, // Location of Duplex Status 10, // Location of Link Status &marvell_phy_cfg // Function pointer to configure Marvell PHY }; alt_tse_phy_add_profile(&MV88E1116R); alt_tse_system_mac sys_mac = {TSE_SYSTEM_MAC(TRIPLE_SPEED_ETHERNET_0)}; alt_tse_system_sgdma sys_sgdma = {TSE_SYSTEM_SGDMA(SGDMA_ETH_TX, SGDMA_ETH_RX)}; alt_tse_system_desc_mem sys_mem = {TSE_SYSTEM_DESC_MEM(RAM_DESCRIPTOR)}; alt_tse_system_shared_fifo sys_sfifo = {TSE_SYSTEM_NO_SHARED_FIFO()}; alt_tse_system_phy sys_phy = {TSE_SYSTEM_PHY(1, NULL)}; alt_tse_system_add_sys(&sys_mac, &sys_sgdma, &sys_mem, &sys_sfifo, &sys_phy ); And console............: Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Created "Inet main" task (Prio: 2) Your Ethernet MAC address is 01:01:20:00:00:00 prepped 1 interface, initializing... Created "clock tick" task (Prio: 3) [tse_mac_init] INFO : TSE MAC 0 found at address 0x01043000 INFO : PHY Marvell 88E1116R found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Explicitly mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 1000, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x0400020b [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 DHCP timed out, going back to default IP address(es) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Please folks, I really need to OK this hardware. ApusLink Copied
Initialization and console output seem to be ok.
What did you try so far? Pinging ip address? Trying connection on port 30? If ping doesn't work try these preliminary tests: - check if ethernet link is up (i.e. NIC link led on or, if you use Windows, ethernet connection notification in the lower right corner of the screen) - if your board has an activity led on the eth connector, check if it blinks whenever a ping request is issued - check your client tcp/ip configuration (ip address 192.168.1.x with x any from 1 to 254, excluding 234; subnet mask 255.255.255.0) - disable dhcp and use a static ip address- Mark as New
The system is not transmitting anything on the RGMII lines. I can see that the phy is receiving traffic. It seems that it is the system itself, so I am going to signaltap the SGDMA's and Nios regs Apus- Mark as New
Ok,
so it is working now. I had mapped the PHY from addr1 to addr0, thinking that it would be a wise thing to do. better leave it to the system. But I am now able to connect and transmit data over Gigabit Lan. You know, if Altera had specified that we had to setup the TSE during startup instead of stating that the package supports 4 different phy's at default, then it would have saved me a lot of time. Anyway, it is cool when it works. thanks. apus- Mark as New
I use a different PHY (National DP83640) and mapped it to addr 1 but I haven't had any problem. If I remember correctly in my case it happened the opposite: it didn't work when mapped to addr0, but I had an error message directly in the console output during initialization.
Regarding the default setup I can tell you this: I have two PHYs on my board and when I configure fpga for using a single TSE and single PHY I don't need to manually setup with the alt_tse_system_add_sys() call. I only added it when I started to use the second TSE/PHY channel. Cris- Mark as New
The inner workings of the code is not very clear to me, I only read enough to get the board up and running.
I am about to start a new layout for a dual phy board. Dual gigabit. How did that work for you? Best regards Apus- Mark as New
I did a minimal debug inside tse driver code and discovered that it can enumerate and setup automatically the devices. If I remember correctly (it was a few months ago...) this works fine as far as you have a single tse. If more than one (like my case was), the successive tse found replaces the previous one in the enumeration list and in the end only the last one was activated. So I had to explicitly call alt_tse_system_add_sys() for both.
From what I saw inside driver code, if you instead have a single tse with multiple PHYs this doesn't apply. Anyway I'm not sure of the inner workings, so it would be better a true Altera expert helps you. PS: mine is a 10/100 PHY, not a Gigabit, but I think this doesn't matter.- Mark as New
I only had to learn enough to get the PCB layout approved. I really do not play with Nios anymore, we have other guys that are much more skilled than me.
Anyway thanks. Apus- Mark as New
Hi Guys,
I am really struggling with what seems to be the same problem you experienced. Being a hardware guy with a small amount of software experience ... all I need to do is get the example working on the Altera ep3C120 development board to get approval to use my design. I have pulled my hair out for two weeks, signal tapped and proven that the phy is passing correct packets to the mac ... and seen that the right statistics are being recorded by the MAC. I have never seen the TX LED light up. Actually that may be a lie because I forced the phy into packet generation mode and was capturing packets with wireshark - the tx led may have gone then. What exactly do I need to do to get this board simplesocketserver example going? I suspect (but lack the reverse softwarer engineering skills to prove) that this might be something to do with the way the phy is addressed...? My thinking is the phy address on this board is 0x12 yet there is only one phy...? Any advice would be good ... the addr1 vs addr0 statement confuses me, and I am not really sure where I should set my phy up in the code anyway ... should I add another 88E1111 to the default list as the comments in the code suggest? Any advice would be appreciated ... I am going nuts here!- Mark as New
this is what i did in order to get my single Marvell to work: (It's been a while...) After that it just worked. I did verify the electronics so i stopped there. In alt_iniche_init.c: void SSSInitialTask(void *task_data) { INT8U error_code; INT32U x,tmp; //Print out the regs to see if it comms with any phy's for(x=0;x<0x320/4;x++) { tmp = IORD(TRIPLE_SPEED_ETHERNET_0_BASE,x); printf("Addr: %x, Dta: %x\n",x*4,tmp); } //Add profile alt_tse_phy_profile MV88E1116R = {"Marvell 88E1116R", // MV88E1111_OUI, // OUI 0x24, // Vender Model Number 0, // Model Revision Number 0x11, // Location of Status Register 14, // Location of Speed Status 13, // Location of Duplex Status 10, // Location of Link Status &marvell_phy_cfg // Function pointer to configure Marvell PHY }; alt_tse_phy_add_profile(&MV88E1116R); alt_tse_system_mac sys_mac = {TSE_SYSTEM_MAC(TRIPLE_SPEED_ETHERNET_0)}; alt_tse_system_sgdma sys_sgdma = {TSE_SYSTEM_SGDMA(SGDMA_ETH_TX, SGDMA_ETH_RX)}; alt_tse_system_desc_mem sys_mem = {TSE_SYSTEM_DESC_MEM(RAM_DESCRIPTOR)}; alt_tse_system_shared_fifo sys_sfifo = {TSE_SYSTEM_NO_SHARED_FIFO()}; alt_tse_system_phy sys_phy = {TSE_SYSTEM_PHY(1, NULL)}; alt_tse_system_add_sys(&sys_mac, &sys_sgdma, &sys_mem, &sys_sfifo, &sys_phy ); /* * Initialize Altera NicheStack TCP/IP Stack - Nios II Edition specific code. * NicheStack is initialized from a task, so that RTOS will have started, and * I/O drivers are available. Two tasks are created: * "Inet main" task with priority 2 * "clock tick" task with priority 3 */ alt_iniche_init(); netmain();- Mark as New
Thanks heaps for explaining this to me ... I really appreciate it. I will try it out and let you know how I get on. I got given another solution which I have physically tried and proven works here (http://www.alteraforum.com/forum/showthread.php?p=95439#post95439) - which was also very helpful.
Thanks again for your help! I am sure many others will benefit from it too.- Mark as New
hi agdepus:
The codes you post here,is the function to realize connection between MAC and PHY? I add your code in my project in NIOSII IDE ,but there are many errors,maybe I donnot understand the communication method and structure well,now I have collect many references about TSE,but I really donnot kown how to realize telecommunication between MAC+PHY and PC,in my lab,there is nobody understand ethernet well. would you tell me the steps of realizing the aim? (my english is not very good,I am very sorry about that) I am appreciate that you could reply me!!- Mark as New
hi,agdepus:
the hardware and software i use are“niosii_ethernet_standard_3c25” and“nichestack_tutorial” from altera pages. In NiosII IDE software, console is below: PHY INFO: [phyid] 0x1 2000 5c90 PHY INFO: Issuing PHY Reset PHY INFO: waiting on PHY link... PHY INFO: PHY link detected, allowing network to start. SSS INFO: Connecting... =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack (http://www.altera.com/nichestack)" ================================================== === InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 EEPROM device 24LC0 size is 10 read[0x000]: control byte 1 was not ACKed Signature = 0x0. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Your NEEK LCD daughtercard is not programmed with a correct MAC Address! Please contact Altera support for instructions on how to correct this problem! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Invalid MAC Address stored at Flash Offset 0x8000 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! Unable to find Valid MAC address. Please refer to your Board's User Guide for instructions on restoring the MAC Address for your board. --Or-- Hard Code MAC address in get_mac_addr() of iniche_init.c !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!! prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x07002800 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 0.0.0.0 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) DHCP timed out, going back to default IP address(es) Nios II Simple Socket Server starting up. Created "monitor_phy" task (Prio: 9) Created "Nios II Simple Socket Server" task (Prio: 10) [SSS_task] Nios II Simple Socket Server listening on port 30 The wrong places are in red my quastions is : 1: how to set correct MAC Address? 2: how to find Valid MAC address? I donnot understand the example very well,can you tell me the efficient steps to learn "ethernet" thanks
