FPGA Intellectual Property
TSE RX Problem
Hello to all,
I´d tried get my system work. But it seems to be an endloss story.
Iám using the Triple Speed Ethernet IP with 10/100/1000 Ethernet MAC. with 2 SGDMA´s one RX one TX and Descriptor Memory...
Sending Frames is no Problem. It works fine. But on Receive Side there are still some problems. I have init the MAC-CMD-Register with
MACwrite(0x02,0x00000033); // enable TX_ENA and RX_ENA PROMIS_EN PAD_EN
Then initialize the RX SGDMA
// Set interrupts for the sgdma receive device --> IEGLOBAL, IE_DESCRIPTOR_COMPLETED Interrupt alt_avalon_sgdma_register_callback( devrx, &rx_ethernet_isr, 0x00000014, NULL ); // Create sgdma receive descriptor alt_avalon_sgdma_construct_stream_to_mem_desc( &descriptor3, &descriptor4, rxbuf, 0, 0 ); // Set up non-blocking transfer of sgdma receive descriptor alt_avalon_sgdma_do_async_transfer( devrx, &descriptor3 );
If I try this the interrupt will never be executed. But when i change Interrupt-source to IE_ERROR the interrupt works. But where does this Error come from???
May you can help.
Seb
Hi to all.
May be it´s helpful for other users. I solved the problem by increasing the RX/TX Fifo in the TSE MAc from 512x32 to 2048x32. I don´t know why this is key. But now the System runs perfect. The aFramesReceivedOK Counter increments with every message i sent...
