I instantiated the variation "10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII PCS" IP variation of the Triple-Speed Ethernet Intel IP core.
I configured the PCS registers as suggested in the user guide:
LINK_TIMER_MSW : x"00000D40"
LINK_TIMER_LSW : x"00000003" -> to get 1.6ms link timer required by SGMII
PCS_IF_MODE : x"00000003" -> SGMII_ENA = 1; USE_SGMII_AN = 1
PCS_CTRL_REG : x"00001140" -> AUTO_NEGOTIATION_
ENABLE = 1; DUPLEX_MODE = 1
PCS_CTRL_REG : x"00009140" -> to reset PCS (after this I repeatedly read the register to check that the reset bit has been cleared)
After reset, before connecting an ethernet cable to a PC, I have the following acquisition from SignalTap:
Signal Tap acquisition before connecting the cable
led_an and led_link are high, therefore I assume that the PCS was able to complete the autonegotiation with the PHY.
After connecting a ethernet cable, I have the following behaviour:
led_an goes low, led_link goes low. I catch those events and reset the PHY (is a TI DP83867IS) writing in its CTRL register. After that, the PCS tries again an autonegotiation, but soon it fails again an I repeat the procedure. The result is that I can't recover the situation.
Signal Tap acquisition after cable connection
My questions are:
1. Is there something that I set wrong in PCS registers?
2. Do I also have to set something in the PHY?
3. Why autonegotiation between PHY and PCS is affected by external cable connection? What do i miss??
Thank you,
Marco
Hi Marco,
As you are facing system level failure, hence it's hard to tell which path went wrong in the first place.
- Is it FPGA design ? On board PHY chip configuration ? your board setup issue ? or the destination Ethernet port or equipment issue
May I suggest you start with something simple to slowly isolate the failure
- You can generate the TSE simulation example design, run the sim to get expected signal behaviour to cross check with your hardware design
- Alternatively, you can also use below TSE reference design to debug your issue
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an647.pdf
dlim
Thank you for the answer dlim.
It is a FPGA design, completely HW based, without NIOS processor. VHDL FSMs configure both the PHY and the TSE.
Actually it seems to be a system level issue. I tried to understand this behaviour for a week without success. During all my tries, for some reasons I also tried to connect the board to another ethernet device (is the USB docking station of the PC, with a ethernet interface) and it seems that the autonegotiation issue is not present here. I can transfer packets from PC to FPGA and viceversa.
Now I think that the problem is relevant the autonegotiation phase between the TI PHY and the external device... and not relevant the configuration of the TSE so I don't think that a simulation of the TSE would help but I'm still trying to figure out a solution.
If you have other suggestion, I will appreciated it.
Thank you,
Marco.
HI Marco,
I see. So, you have further isolated the issue to be within Ti PHY and external device.
Common Ethernet setting that you should watch out is like below
- Speed - 1G, 100M, 10M
- Full duplex vs half duplex
- Autonegotiation on/off
Below is good article that talks about common factor with autonegotiation failure
- https://www.fiberoptics4sale.com/blogs/archive-posts/95041222-what-is-ethernet-auto-negotiation#:~:text=Auto%2Dnegotiation%20is%20the%20feature,values%20determined%20for%20the%20link.
- Pls ensure you configure auto-negotiation enabled for both Ti PHY and external device
- Pls ensure you configure same duplex mode on both Ti PHY and external device. Don't do one side 100/half setting while the other side 100/full setting
As for TSE IP autonegotiation setting, you want to watch out for PHY mode vs MAC mode setting
- PHY mode = the speed and duplex mode of our FPGA and external device will be resolved based on the value set in the dev_ability register. Meaning PHY mode is for advertise the link speed and duplex mode to the link partner
- MAC mode is wait for the link speed and duplex mode from link partner and then resolve based on the link_partner ability register.
- One side should be set as PHY mode and the other side should be set as MAC mode
dlim
HI,
I have not hear back from you for a while.
Hopefully my earlier feedback is useful for u
For now, I am setting this case to closure.
dlim
