I am trying to tap a working video design that captures live video from a CCD camera and displays it on the lcd. As, Quartus v12 provides IPs for tapping avalon-ST data i.e. avalon-ST video monitor and trace system megacore functions so i used them. BUT when when I synthesize my new design, it generates following error:
--- Quote Start --- Error (10228): Verilog HDL error at altera_avalon_st_pipeline_base.v(22): module "altera_avalon_st_pipeline_base" cannot be declared more than once --- Quote End --- As far as i get it, module name "altera_avalon_st_pipeline_base" is getting repeated within the project but the path for "altera_avalon_st_pipeline_base.v" is --- Quote Start --- project directory\trace_system_1\ altera_jtag_dc_streaming\altera_avalon_st_pipeline_base.v --- Quote End --- ...which indicates that error lies in trace system megacore generated files. does anybody have a clue how to fix this???Link Copied
I'm trying to guess what might be wrong with your system but I'm guessing so please confirm that I've guessed right.
- Are you using SOPCB or QSYS?
- Do you have multiple QSYS hierarchies in your Quartus project (ie are you running generate multiple times)?
- How are you including the files into Quartus?
- What version of Quartus are you using?
Thnx wombat!
- I am using SOPC Builder,
- There is single SOPC builder hierarchy in my Quartus project
- And its Quartus II 12.0sp2 Web Edition (32-Bit)
Is it possible to upgrade your project to QSYS? I suspect that if you do that will fix the problem.
If not then please check that the two copies of the pipeline_base.v file are the same. If they are then deleting one of them should make the design compile. I really do recommend upgrading to QSYS unless you have good reasons why not though, as it's possible that you'll hit problems later on with SOPCB.- Mark as New
Unfortunately, it is not possible to upgrade to Qsys currently due to shortage of time. Nevertheless, I have deleted the redundant copies of same file and project gets compiled. BUT when i load my design in system console it doesn't detect trace system module...any ideas??
