FPGA Intellectual Property
6260 Discussions
Tried HD-SDI in smaller GX15 package?
Has anyone tried using Altera's IP-SDI with HD-SDI on smaller package like the C4-GX15 or GX22 ?
Anyone knows why Altera do not want to support HD-SDI in a device where the transceiver is capable of handling twice the required speed. Then What's the point of even putting transceiver into these chips?
Puzzled, Paul
Maybe not enough PLLs? Impossible to meet timing? Ask Your Altera FAE.
Well, I do not think so. There must be a MPLL that is "absorbed" into the IP-core block for it to work. The same fabric with similar speed, as specified in the datasheet for all the different die size. The only difference is the lead-frame, which lead to slightly lower speed limit on its I/O pin. To add to the gist, the whole chip does nothing but just a transceiver and IP-core. Utilization is less than 5% !!
Asking FAE, will be difficult, as some are 'hiding' behind the published user's guide and try to give me a 'textbook' answer.
Then it's probably marketing.
More like marketing and resources now. It is badly maintained, with too much inflexibility around a so-call FPGA. It tells you, can do this and that in the datasheet and handbook, but Quartus will not allow it.
