Hello
I 'm using the simple_socker_server exemple proposed with the Cyclone 10GX dev kit. The FPGA card is connected to a PC through a 1 Gbps Ethernet link. The exemple is working well with out any PB. In order to evaluate the data rate performance, I added in the SSSSimpleSocketServerTask a loop to transmit 10 000 time a buffer of 1 ko with the send() function. The transfer takes 8 s to be completed. By replacing the FPGA dev kit by a socket server implemented in a PC through the same 1 Gbps Ethernet link, the transfer takes roughly 0.2 s. Where does the problem com from ?
Thank you for your help
Best regards
Etienne
The 8s include the board startup time? can you confirm?
BTW the C10 GX simple socket server is no longer available which, can you please check again and share with me screenshots of the design?
Thanks for the shared files,
I will have a look into it and will let you know.
Any news about the "Triple Speed Ethernet" data rate problem?
Very best regards
Etienne
Sorry, sir, I cannot download these files, can you upload it here?
