FPGA Intellectual Property
Annonces
6673 Discussions
Triple-Speed register configuration
Contributeur émérite II
1 163 Visites
Hi all. I'm using tse single port rgmii arria v gx project (AN647) and configure command_config register fields via tcl scripts. Is there a possibility to configure this register in project, to avoid doing this every time after programing FPGA?
Thanks for your time.
0 Compliments
2 Réponses
431 Visites
Hi,Andrey13! Can you tell me how to configure register with tcl scripts? The user guide says:
"At the minimum, you must
configure the following functions:
• Primary MAC address (mac_0/mac_1)
• Enable transmit and receive paths (TX_ENA and RX_ENA bits in the
command_config register)"
But I don't know how to write these registers.
Anything can help!
Best wishes!
0 Compliments
431 Visites
Hi, siepha. You must connect your board with JTAG interface. Then go to Qsys -> Tools -> System Console. Set the root directory with your tcl scripts "cd C:/.../sc_tcl". Then run config.tcl "source config.tcl". Good luck!
0 Compliments
Répondre
