FPGA Intellectual Property
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
6319 Discussions
UART IP - input clock
I'm using a MAX10 FPGA and I'm trying to generate a UART IP core. During the generation process, after I select the buad rate, stop, parity bits, I get an error "the input clock frequency must be known at generation time". This error makes sense. But how do I set the clock frequency? I've looked though various menus, and did not find anything.
Thank you.
Alin
Refer below link
https://www.altera.com/support/support-resources/knowledge-base/ip/2018/error--rs232_0--the-input-clock-frequency-must-be-known-at-gener.html
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
