FPGA Intellectual Property
6596 Discussions
Using Altera PLL make 500Khz or below
jjang
When i Using ALTPLL, i Usually make 500khz and below xx kHz Frequency Clock. @ 50Mhz  / 100Mhz Input clock.
But Cyclone 5,  Different PLL IP Core.
 - ALTPLL → Altera PLL,  so it doesn't support for Low Frequency Clock.
 does have any way to make 500kHz or 10kHz frequency Clock?
FvM
just read PLL Intel FPGA IP messages thoroughly. It instructs you to enable physical output clock pararameters to configure cascaded output counters.
FvM
all Intel FPGA starting with Cyclone III have a post-scale counter cascading feature and can generate output frequencies down to a few kHz, also Cyclone V.
Frank
jjang
As Clocking and PLL User Guide..
Using PLL Clock (C1, C2. C3.C4), then that can though Global clock.
but to make a Clock as  a Logic (such as Counter).. will not connect to Global clock . .isn't it?
FvM
AqidAyman_Intel
I wish to follow up on this issue. Have you able to use the cascading feature to generate the low frequencies output clock?
Aqid
