FPGA Intellectual Property
6670 Discussions
Using CIC Decimation Filter with Multi-channel Support
Hi All,
I have questions about this designe example:
http://www.altera.com/support/examples/dsp-builder/exm-cic-decimation-filter.html
I have attached the design files. In the file fir_compiler_v7_2.vhd, it goes
"number_of_input_channels" value="2"
"input_bit_width" value="16"
"output_bit_width" value="35"
So the two input channels of fir conveys 8-bit 'I' and 8-bit 'Q' data respectively (correct me if it is wrong). Does that mean 'I' and 'Q' are merged into 35-bit packet on the output interface so the first half contains 'I' and the second half has 'Q'?
Then the 35-bit output is sent to Avalon-ST Packet Format Converter. The converter seperates the 35-bit 'IQ' packet into two sources, 35-bit 'I' and 35-bit 'Q'. Does the converter perform the bit extension to add more bits to I and Q outputs, respectively, to have the bit width of 35?
Many Thanks,
Lee
--- Quote Start ---
Hi All,
Many Thanks,
Lee
--- Quote End ---
I would think that each of I and Q is 16 bits wide. The final result of each is 35 bits wide. I and Q results are interleaved at FIR output and dinterleaved by the converter.
Hi Kaz,
You mentioned "I and Q are interleaved at FIR output". What does interleaved mean? Does that mean there are two output channels for 35-bit I and 35-bit Q, respectively?
Lee
--- Quote Start ---
Hi Kaz,
Lee
--- Quote End ---
Yes that is what I imagine as I-Q-I-Q-...
you can check that by setting I input to zeros and Q to nonzeros
Hi Kaz,
I'm trying to run the simulink model CICDownMISO.mdl but I re-created the model using 13.1 version of CIC and FIR compilers and re-named it as CICExample.mdl. I have attached the file. In the Step bolck, it has the parameter Sample time: clock1. I got an error saying undefined variable clock1. How do I define clock1 in the model? I'm very new to Simulink DSP Builder.
Lee
The assignment of variable clock1 can be found here:
In the Simulink model,
File->Model Properties -> Callbacks (Tab) -> InitFcn* (Model Initialization Function)-> clock1 = 1; ....
Hi All,
How to decide the bit width for the fir filter coefficient? Is the bit width the same as the input data bit width?
Many Thanks,
Lee
--- Quote Start ---
Hi All,
Many Thanks,
Lee
--- Quote End ---
quantise your coeffs and see response. If you and spec are happy with it so be it.
