In one of our CIII board, we need to use 88E1111. My question is: do we need to make sure the length of all data line(TXD, RXD) are the same in order to achieve maximum data rate? How about control lines? Thanks and Best regards, KevinLink Copied
"the same in order" sounds reasonable. Check the chip specification for tolerable delay skew with either GMII or RGMII interface and calculate the setup and hold margin depending on the FPGA side of the interface. I would expect, that a trace length difference up to 1-2" can be tolerated in most designs.
you can consultant vendor.
