FPGA Intellectual Property
6262 Discussions
V-Series Avalon-MM DMA Interface PCI-E MSI example
Dear All,
I need some example project for implementing MSI / MSI-X for "V-Series Avalon-MM DMA Interface" IP core.
My status is:
  1. I was using Avalon-MM Cyclone V HIP for PCI-Express, and familiar with legacy interrupt a few years ago.
  2. Now, There is a niche requirement asking me to use the DMA interface, but by the meanwhile open a low-speed channel to report certain events back to the host.
  3. I am looking at implementing MSI (which is new to me).
The issue is I am missing the correct direction for the documents. The MSI knowledge on the IP core user guides and application notes are rarely mentioned.
So, can anyone point me a right direction for implementing MSI Interrupt for "V-Series Avalon-MM DMA Interface"
Plus, in the QSys, I saw the IP exported most MSI signals as conduits, except "MsiControl_o[15:0]" Can anyone tell me how to make it "show-up"?
Thanks and Regards,
Xu Li
https://alteraforum.com/forum/attachment.php?attachmentid=15004&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=15005&stc=1
A quick follow up: Thanks to Jeff, the link below helps a lot with PCI-E MSI and MSI-X:
http://www.alterawiki.com/wiki/implementing_msi-x_for_pci_express_in_altera_fpga_devices
