FPGA Intellectual Property
5984 Discussions
VHDL simulation of Uniphy DDR3 controller
I have no idea what I'm doing wrong.
I'm generating a VHDL DDR3 Uniphy controller with the MegaWizard (Quartus 10.1).
I wanted to simulate the example design, but I 'm running into 2 problems:
- all testbench files in <variation_name>_example_design_fileset folder are Verilog only (including testbench top, example driver, ...)
- the simulation oriented version of the controller <variation_name>_sim folder is a VHDL file (an encrypted .vho file), but it does not compile correctly in ModelSim!
Did anyone succeed in simulating Uniphy in VHDL language?
Note: of course I don't have a Verilog license available for ModelSim.
JC
this was an issue 10.0, but was supposed to be fixed in 10.1:
http://www.altera.com/literature/rn/rn_ip.pdf
maybe the work around provided in the errata will help
Thank you for pointing me to this errata list.
According to this list, the root cause of my problem is that I should not use the half rate bridge feature (feature that allows to implement a local interface with half the rate of the clock sent to the memory device).
Unfortunately, the document states that:
- The half rate bridge feature is not supported by Quartus 10.1
- The half rate bridge feature is supported by Quartus 10.0, but attempts to generate a VHDL IP leads to verilog files.
This means that UniPHY is not a usable option for me yet.
I'll switch back to a good old ALTMEMPHY solution then ...
