FPGA Intellectual Property
6673 Discussions
VIP SCALER II output data all zero
When I run the SCALER II with no control port, I use the bicubic way. And I have no .mif file
The control packet can output correctly, but the video packet output is all zero.
The valid, ready, sop and eop are output correctly.
My datapath is as follows: deinterlace II --> CLIP --> SCALER II --> FRAME BUFFER
Can anyone help me to solve this problem, thanks
Hi Jiangsuren,
You will get the zero video packet out in the simulation could be due to the *mif file is missing.
Could you please copy the coefficient .*mif file to your simulation directory from the following folder?
\synthesis\submodules\src_hdl
Please also check if there is any warning or error message from the simulation.
Terence
(This message was posted on behalf of Intel Corporation)
Thanks, it can run now
