FPGA Intellectual Property
6673 Discussions
VIP Suite Clocked Video Input/Output Sync Problem
Hi
I'm a newbie trying to use the Video and Image Porcessing Suite with the Altera Cyclone III Development Board (EP3C120F780C7) and the Bitec HSMC DVI interface.
I tried to get color bars on a screen with this design :
Test Pattern Generator -> Clocked Video Output : it works.
The parameters for the CVO are : for 1280x720p@60Hz
1280x720
hor sync. : 128 pixels
hor front porch : 64 pixels
hor back porch : 192 pixels
ver sync : 5 lines
ver front porch : 3 lines
ver back porch : 20 lines
My problem is :
I am using the analog interface AD9981 (from Analog Devices) to convert analog video signal to digital video signal.
My design is :
Clocked Video Input -> Clocked Video Output
The AD9981 is configured to work in 720p@60Hz and i keep the same parameters as my first design for the CVO, but I get nothing on screen.
It seems that there is a problem with the horizontal sync output : there are only 14 lines for the vertical back porch although I put 20 lines in the "vertical back porch" parameter
Can anyone help me please!!
Thanks!
Dath
Hi Dath
You should check about In/Out Vid Clock diffrence.
Are you using same clock?
If In/Out clock different, It require Frame Buffer in VIP. Good Luck to you!!
not an easy task.
Hi dath,
I am trying create Test Pattern Gen -> CVO. I connected
vga_clocked_video_vid_clk(clk_25), // vga_clocked_video.vid_clk
vga_clocked_video_vid_data(rgb_data), // .vid_data
vga_clocked_video_underflow(), // .underflow
vga_clocked_video_vid_datavalid(vid_datavalid), // .vid_datavalid
vga_clocked_video_vid_v_sync(v_sync), // .vid_v_sync
vga_clocked_video_vid_h_sync(h_sync), // .vid_h_sync
vga_clocked_video_vid_f(), // .vid_f
vga_clocked_video_vid_h(), // .vid_h
vga_clocked_video_vid_v()
Then assigned it to VGA pins
assign VGA_SYNC_n = 1'b1;
assign VGA_R = rgb_data[23:16];
assign VGA_G = rgb_data[15:8];
assign VGA_B = rgb_data[7:0];
assign VGA_BLANK_n = vid_datavalid;
assign VGA_CLK = !clk_25;
assign VGA_HS = !h_sync;
assign VGA_VS = !v_sync;
But it still didnt work. Can you tell me where I should reconnect?
I would appreciate your help!!
Frame Buffer is a must in this situation.
