FPGA Intellectual Property
VIP - Video mirroring
I'm using the VIP-core with a CycloneIII-dev-board and it's working fine.
Now I have to add a function, which turns the video upside-down or mirrors it.
I can't find such a function. What must I do?
Best Regards
Mark
there's a fellow on the forum who built a mirror function, it should be an afternoon project. all you need is a couple of ping pong line buffers which you load 0 to N and read N to 0
going top to bottom will require a full frame buffer and is a much more complicated project
Unfortunately I have to mirror it from the top to the bottom.
The design is already using the VIP frame buffer for changing refresh rate,
but the frame buffer doesn't have a mirror function.
right, you will have to build your own frame buffer so you can read out the lines in the reverse order
