FPGA Intellectual Property
6569 Discussions
VIP scaler problem:cann't dynamically control the input image width
I'm using quartus9.1 to generate an scaler. I configured the scaler as following:
turn off the Run-time control of image size
input image width 300
intput image height 300
output image width 100
output image hight 100
parallel.
other settings are default.
If I test the scaler as described above(the control packet set the input format as:300*300), the circuit behaves normall.
However,when I changed the input image size to 100*100 in the circuit using a control packet(I'm quite sure that the control packet format is correct) ,the scaler could not behave correctly.At the end of the simulation, the dout_startofpacket goes high and dout_endofpacket never goes high.
What's the problem here?
The scaler Run-time control of image size has to be enabled otherwise the scaler will ignore your control packets.
Thank you. I think the vip userguide is too vague.Only after you have tried a lot of time can you finally understand what it really means.
