FPGA Intellectual Property
VREF
ymiler
Hi
1) Is there option to define which VREF the FPGA use  ?  (interal FPGA vref   or  external IO pin )
    If yes - where should I define it in the Quartus
2)Do all the banks should get same vref ?
3)How can I make same vref  value when I transfer SERDES data from FPGA to other ( each FPGA locate in other board)
Yishay
AminT_Intel
May I know which FPGA are you using?
Thank you.
ymiler
Hi
DEVICE 1SG10MHN3F74C2LG_U1
FAMILY "Stratix 10"
AminT_Intel
Hello Yishay,
Hope you are doing well. You can define Vref by using Pin Planner in your Quartus. There is an external VREF pin for every I/O bank, providing one external VREF source for all I/Os in the same bank. You can refer to page 40 from Stratix 10 GPIO User Guide
Additional documents that you can refer to is as below:
1. Intel Stratix 10 Device Datasheet
2. LVDS SERDES IP User Guide
Thank you.
ymiler
Hi
Thank you for your answer ,
According to the DS  there is option to choose which VREF to use ,  internal or exteranal
Attached screenshot :
But , I dont find any option choose it in the Pin Planner :
Please advise
Yishay
AminT_Intel
Which version of Quartus are you using?
ymiler
AminT_Intel
When you click on that GUI in the Pin Planner it will show you the pin location on tab on your right. You can set your fitter location to that pin at the bottom of the Pin Planner GUI.
Thank you.
AminT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
