FPGA Intellectual Property
6670 Discussions
Verilog module Instantiation
Don't really know whether i should post this Q here or not.
I'm a student using modelsimSE 6.1f.
actually this Q is more to verilog...not on fpga hardware issue
i was wondering,how can i control the input to an instantiated module?
e.g:
module bin2bcdAdder(input1,input2,bcd);
full_adder fa1(input1,input2,SUM,carryOut);
endmodule
the testbench generates 0000 to 1111 into the module bin2bcdAdder
how can i control the input only from 0000 to 1001 can be passed to the instantiated module full_adder?
and i'm trully sorry if i post this Q in the wrong section, or altera forum is only allowing altera's hardware related Q
You basicaly need to add soething like this somewhere in your code
if (input == 1001) begin
input <= 4'b0;
end
But I guess you have no clue where to add it right ?
Well, I can not help you there, not without the code.
module bin2bcdAdder(input1,input2,bcd); input input1,input2; output bcd; wire S; wire input1,input2; /*without this line, i can't assign the input values to A1,B1 and compile the code*/ reg A1,B1; addminus4bit am4b(A1,B1,0,S,V,C); always @ (A,B) begin if(A>1001|B>1001) begin A1=4'b0; B1=4'b0; end else begin A1=input1; B1=input2; end /*some codes here*/ end endmodulewell,i tried using the always block...
or is it useless to use the > comparison?
do i need to do case for each bit from 0000 to 1001?
module bin2bcdAdder(input1,input2,bcd); input input1,input2; output bcd; wire S; wire input1,input2; /*without this line, i can't assign the input values to A1,B1 and compile the code*/ reg A1,B1; addminus4bit am4b(A1,B1,0,S,V,C); always @ (A,B) // without a clock input this will NEVER work begin if((A>4'b1001)|(B>4'b1001)) begin A1<=4'b0; // proper assigments B1<=4'b0; //proper assigments end else begin A1<=input1; // proper assigments B1<=input2; // proper assigments end /*some codes here*/ end endmodule
--- Quote Start ---
--- Quote End ---
not all always block needs a clock rite?may i know why do i need a clock pulse for this one?
btw,it's all working now...tq^^
added A1 and B1 to the output port to simulate it and it runs well
without the clock generation
I am getting error while instantiating modules on condition with the default module. it is giving error if i instantiate default mode.
the code is much similar to this:
module top(//parameters);
addition u0(//parameters passing); line 2
'ifdef(flag)
sum u1(//passing the parameters);
'else
subtract u2(//passing the parameters);
'endif
endmodule
if the module addition-u0 is removed, then only code is working properly. but i need to operate before conditional execution.
plz help me.:cry:
