Below warning are generated when fitter 10M16DCU324I7G
Nios and Uniphy IP was used for DDR2 RAM.
What should I do?
Warning (14285): Synthesized away the following RAM node(s):
Warning (14320): Synthesized away node "nios_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0|nios_mem_if_ddr2_emif_0_s0:s0|rw_manager_ddr2:sequencer_rw_mgr_inst|rw_manager_generic:rw_mgr_inst|rw_manager_core:rw_mgr_core_inst|rw_manager_di_buffer_wrap:di_buffer_wrap_i|rw_manager_di_buffer:rw_manager_di_buffer_i|altsyncram:altsyncram_component|altsyncram_uok1:auto_generated|q_b[8]"
Warning (15055): PLL "nios_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0|nios_mem_if_ddr2_emif_0_pll0:pll0|altpll:upll_memphy|altpll_i0j3:auto_generated|pll1" input clock inclk[0] is not fully compensated and may have reduced jitter performance because it is fed by a non-dedicated input
Info (15024): Input port INCLK[0] of node "nios_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0|nios_mem_if_ddr2_emif_0_pll0:pll0|altpll:upll_memphy|altpll_i0j3:auto_generated|pll1" is driven by clock_pll:clock_pll_0|clockpll:clk|altpll:altpll_component|clockpll_altpll:auto_generated|wire_pll1_clk[1]~clkctrl which is OUTCLK output port of Clock control block type node clock_pll:clock_pll_0|clockpll:clk|altpll:altpll_component|clockpll_altpll:auto_generated|wire_pll1_clk[1]~clkctrl
Warning (15058): PLL "nios_mem_if_ddr2_emif_0:mem_if_ddr2_emif_0|nios_mem_if_ddr2_emif_0_pll0:pll0|altpll:upll_memphy|altpll_i0j3:auto_generated|pll1" is in normal or source synchronous mode with output clock "compensate_clock" set to clk[1] that is not fully compensated because it feeds an output pin -- only PLLs in zero delay buffer mode can fully compensate output pins
Warning (169064): Following 2 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results
Info (169065): Pin memory_mem_ck[0] has a permanently enabled output enable
Info (169065): Pin memory_mem_ck_n[0] has a permanently enabled output enable
Warning (169202): Inconsistent VCCIO across multiple banks of configuration pins. The configuration pins are contained in 2 banks in 'Internal Configuration' configuration scheme and there are 2 different VCCIOs.
Hi, Xiaoqiang
You may refer to below:
The q_b[8] may be not in usage, and therefore it is synthesized away.
The configuration pins have to be at the same voltage level, may be you need to check if the VCCIO of all the configuration pins are at the same voltage level. Alternatively, you can allocate all the configuration pins under one IO bank which has one voltage level.
Eric
Hi, Xiaoqiang
Pin memory_mem_ck[0] and pin memory_mem_ck_n[0] are either have no output enable, or they are VCC and GND enable.
If you enable them later, it will change your fitting result. You may want to add an output enable that is not GND/VCC to them.
Eric
Hi, Xiaoqiang
You may want to check if INCLK[0] is a dedicated clock input pin.
Eric
Hi, Xiaoqiang
Can we close the case if you have no more question ?
Eric
