Hello guys, I'm new with Altera so I'll be really happy if you help me.
I'm following an Altera tutorial and it teach to add a PLL Megafunction/Base Suite as follows: - right click > edit > insert symbol; - Click megawizard plug-in manager; - Click next; And on the left shoul appear a list on the field select a megafunction from the list below; but I see nothing, only a empty IP MegaStore/Base Suite icon on the tree. I'm using the Quartus-II WEB 11 SP1 once my dev board do not accept newer releases... I'm using the EP1C3T144C8. Please Help me to populate the IP list :)Link Copied
Generally you should expect to see a dropdown list of megafunction ie Arithmetic, Communication, I/O, PLL and etc. Is it that there is no dropdown at all? Probably some screenshot will be helpful for better understanding.
Just wonder if re-installing your Quartus software will help? You can also try with subsription version and see if similar error exist. There should be 30 days evaluation if not mistaken.
Can u find the megafunction library in Quartus directory?
Just wonder if you select other device, the similar issue persists?
