FPGA Intellectual Property
6598 Discussions
Where's the Avalon Microsequencer???
I finally found a good app for the Microsequencer. But I don't see it in the SOPC Builder v9.1, nor does google return non-stale documentation on it.
Did Altera remove it from SOPC Builder??? :confused:
-- Pete
I believe I know the guy who wrote it. Let me ask him about it. Alternatively, you can try copying it over to the \altera\91\ip\altera\sopc_builder_components directory from an old install.
Jake
Ok I tracked down an instantiated version of the uSequencer from an old project. I added some stuff to it (code update port) and gave it a GUI so it's risen from the ashes!
I originally tried to install the version I had but it said I required Quartus v3.0 or later ... I have Quartus v9.1! Anyways, the .ptf file would have probably been completely useless in the latest SOPC Builder.
Thanks for your efforts though!
-- Pete
I spoke to the designer. He said the component needed to be updated for 9.1. He was going to look into it. Sounds like you got it figured out.
Jake
Hi all,
which version of old Quartus do i need to install, when i want to use Avalon microsequencer?
I tried to use install from
http://www.alterawiki.com/wiki/avalon_microsequencer
but it told me, that i need to have Quartus SOPC Builder 3.0 and later. I have Quartus 13 with QSys and Quartus 12 with SOPC Builder, but it doesnt work.
Thank you very much.
Honza Naceradsky
