FPGA Intellectual Property
6260 Discussions
Why NCO IP outputs ZERO?
LZhao1
Partner
when customer use a NCO IP on Arri10 SX, in Quartus Prime 19.2pro, found that output SIN and COS both are ZERO
KhaiChein_Y_Intel
Could you provide more details? Can you provide a test case and result for investigation?
LZhao1
Partner
Hi, We found that in Quartus 19.2pro, some .hex files generated by NCO IP has a mismatch location where system needs, so we manually move those .hex files to correct location, then, NCO IP can function right. Maybe in Quartus 19.4pro can fix the problem, I have not verify yet.
KhaiChein_Y_Intel
Can you provide the design and steps to reproduce the error?
KhaiY
KhaiChein_Y_Intel
May I know if you have any updates?
KhaiY
LZhao1
Partner
Hi, The issue has been solved, thanks for your support!
