FPGA Intellectual Property
6565 Discussions
Why does the auto precharge input signal disappear in Qsys for the DDR3 memory controller IP block when Hard Memory Interface is enabled?
JWils26
The enable Auto-Precharge Control option remains selected, but if you change between not using the Hard interface to using it, the signal is no longer present in Qsys. This is targeting a Cyclone V SoC, IP is the DDR3 SDRAM Controller with UniPHY Intel PFGA IP.
NurAida_A_Intel
Hi JWils26,
Unfortunately hard memory controller doesn't support auto-precharge control and won't enable "local_autopch_req" as shown in attachment.
You can consider to use regular soft memory controller that support auto-precharge control (uncheck hard memory interface) option in DDR3 UNIPHY IP.
I am really sorry for any inconvenience cause.
NAli1
