FPGA Intellectual Property
6359 Discussions
Writing to control and status register from the code and from system console scripts
LSant1
How can I write to a control and status register from the code and the system console script?
sstrell
Once you've set up a master path in System Console, use a master_write command to write to a particular address location. Check out this online training to learn more about System Console:
https://www.intel.com/content/www/us/en/programmable/support/training/course/oemb1117.html
#iwork4intel
LSant1
I am able to write from the console. But if csr write is set to 1 in the code, I cannot write from the console script.
sstrell
I don't understand. Can you post the code and exactly what is happening?
#iwork4intel
LSant1
Currently I am setting registers from the console and am trying to pass the values from the code. But I still want console access for debug. For example, I wrote to the MAC reset control register in Arria10 (0x08FF). I am able to set it and reset it from the console when csr write in the code is 0. But if I set csr write to 1 in the code, then am not able to write to change the value from the console.
LSant1
I am using the 10G MAC design example which has the address decoder block. I want to hook up the 10G core to another bus and set the registers from it. But I still want to be able to run scripts to change these registers from the system console. Is that possible?
