Tell me about the Internal Weak Pull-Up of cyclone10LP.
For before and during configuration, is weak pull-up enabled regardless of the weak pull-up resistor setting?
best regard
Goto
Thank you for contacting Intel community.
Please explain further on your question, or you can also refer to below link:
For Cyclone 10 LP
Kindly refer to Cyclone 10 LP datasheet below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51002.p... (page 13, Table 11)
Pin connection guidelines for Cyclone 10 LP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/pcg-01021.pdf
Cyclone 10 LP device design guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an800.pdf
Aiman
Thank you for your answer to me.
I checked Table 11 on page 13 of the Cyclone10LP Device Database.
Is the weak pull-up resistor as follows?
When the weak pull-up resistor is set to ON, the pull-up resistor is inserted before and during configuration, and in user mode.
When the weak pull-up resistor is set to OFF, the pull-up resistor does not enter (that is, high impedance) before and during configuration, and in all user modes.
best regards,
Goto
Yes, that's true.
Aiman
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
