FPGA Intellectual Property
6359 Discussions
about the IP core legacy EPCS/EPCQx1 Flash Controller does not support cyclone 10LP
:confused:
I'm confused about this IP core, because it doesn't support my new FPGA cyclone 10LP. Can someone give me any advise?
Yes, It's is not supported.
Check the link which addresses the same issue.
https://www.alteraforum.com/forum/showthread.php?t=58035
Alternate are ASMI Parallel IP or ASMI Parallel II IP which has a similar feature
https://www.altera.com/en_us/pdfs/li...i_parallel.pdf
https://www.altera.com/content/dam/a...g/ug-asmi2.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
I'm so sorry to reply you after so long time. As a fresh hand, because I regard the username as the Email address, I can't log in until now. And I 'm preparing exams these days, so I always forget it. After reading the addresses, I figure out it. Thanks for your help~
Best wishes,
MelonEater
(An undergraduate from China)
Hello, I find that Quartus18.0 still don't support this IP. But it said this would be solved in 18.0 in this address "https://www.alteraforum.com/forum/sh...ad.php?t=58035".
The document has been updated.
Check the link session 15.1-> Note
https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf
Anand Raj Shankar
Thank you very much, I will look it up carefully later!
Best wishes.
