Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
about the signal of "ff_rx_dsav"
when I simulated the Triple speed ethernet MAC,I added a data interface contro module to the mac,I found the signal ff_rx_data[7:0] have data stream out,but there are serval "00" bytes in the stream and the signal ff_rx_dsav was deasserted and rx_err[5:0]=6'b000110,how does that happen?
I set the mac interface register as following:
register offsetregister namevalue0x08command_config0x0080_00330x04scratch0xAAAAAAAA0x0Cmac_00x17231C00
0x10mac_10x0000CB4A
0x14
frame_length
0x5ee
0x18
pause_quant
0x0f
0x1C
RX_section_empty
0x10
0x20
RX_section_full
0x10
0x24
TX_section_empty
0x100x28
TX_section_full
0x10
0x2C
RX_almost_empty
0x08
0x30
RX_almost_full
0x08
0x34
TX_almost_empty
0x08
0x38
TX_almost_full
0x0A
ox3c 0x00
0x5c 0x0c
0xe8 0x00
0xec 0x00
Highlighted
What are you sending on the MII side? The error word that you get seems to indicate "CRC error" and "Invalid frame length"
Highlighted
Thank you for your reply!
Firstly,I added data stream to "ff_tx_data",then the gm_tx_d[7:0] have data out.
secondly,I copy the out data and the signal of enable to gm_tx_d[7:0] interface.
Highlighted
Did you create a loopback?
Quartus creates a testbench with the TSE component. It could be a good idea to try and run it and compare with yours.
