FPGA Intellectual Property
6343 Discussions
about xcvr_vccr_vcct_voltage set
lambert_yu
Hi all,
    I have one question:
     if the Vccr_GXB = 1.07v, so the xcvr_vccr_vcct_voltage is 1_0V or 1_1V? Which one will be the best setting? If I set xcvr_vccr_vcct_voltage to 1_0V is okay? For data rate = 12Gbps, will I need to set xcvr_vccr_vcct_voltage to 1_1V?
   FPGA TYPE : arria 10, 10ax115n2f45e1sg
Brs,
Lambert
Deshi_Intel
Welcome.
So, if your on board power supply typical value is 1.03V and may fluctuate till max 1.06V/1.07v then maybe still fine but if your typical value is already 1.06v/1.07v then it's a bit high and out of recommended operation condition from Arria 10 datasheet.
Deshi_Intel
HI Lambert,
Quartus setting of 0.9V, 1.0V and 1.1V basically correspond to on board supply of 0.95V, 1.03V and 1.12V.
  • 1.1V/1.12V setting is only applicable to GT channel only while I presume you are using GX channel
For GX channel, Transceiver speedgrade of 2, data rate = 12G,
In general, you can always refer to A10 datasheet doc for the guidance of correct transceiver power supply to be used.
dlim
lambert_yu
Hi dlim,
    Thanks for your help,  just because I provide one  very close value to 1.06v(maximum, 1.07v just because of the power accuracy adjustment). And from your information, I got the indication of 0_9v, 1_0v, 1_1v, thanks.
Brs,
Lambert
Deshi_Intel
Welcome.
lambert_yu
Deshi_Intel
No problem !
