Hi all,
I have one question:
if the Vccr_GXB = 1.07v, so the xcvr_vccr_vcct_voltage is 1_0V or 1_1V? Which one will be the best setting? If I set xcvr_vccr_vcct_voltage to 1_0V is okay? For data rate = 12Gbps, will I need to set xcvr_vccr_vcct_voltage to 1_1V?
FPGA TYPE : arria 10, 10ax115n2f45e1sg
Brs,
Lambert
Welcome.
So, if your on board power supply typical value is 1.03V and may fluctuate till max 1.06V/1.07v then maybe still fine but if your typical value is already 1.06v/1.07v then it's a bit high and out of recommended operation condition from Arria 10 datasheet.
HI Lambert,
Quartus setting of 0.9V, 1.0V and 1.1V basically correspond to on board supply of 0.95V, 1.03V and 1.12V.
- 1.1V/1.12V setting is only applicable to GT channel only while I presume you are using GX channel
For GX channel, Transceiver speedgrade of 2, data rate = 12G,
- You should be using 1.03V as per A10 datasheet table 20 Transmitter and Receiver Data Rate Performance (page 25)
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.p...
- May I know why are you using 1.07V ?
In general, you can always refer to A10 datasheet doc for the guidance of correct transceiver power supply to be used.
dlim
Hi dlim,
Thanks for your help, just because I provide one very close value to 1.06v(maximum, 1.07v just because of the power accuracy adjustment). And from your information, I got the indication of 0_9v, 1_0v, 1_1v, thanks.
Brs,
Lambert
Welcome.
No problem !
