FPGA Intellectual Property
6382 Discussions
adding color to grey scale video
I have a system that generates 8-bit grey scale video. The frame data is in ram, 8-bit grey scale 656 format. Depending upon the value of each pixel I want to be able to colorize the data. I really have no idea as to how to do that. Does anyone have any suggestions?
If its grey scale, you cannot colourise it without the colour information, unless you are trying to colourise it for some other meaning?
The video data represents temperature for each pixel so I want to, say for instance, if a particular pixel is above a certain temperature, make that pixel red, or a group of pixels to represent a temp gradient, how would I do that.
what format is your video output? is it RGB or YCbCr?
YCbCr is the current format.
You will need to take your RGB value and convert it to YCbCr via a colour space converter, or just have a set of preset YCbCr values. Then you will need to convert it to 444 to 422 video for output (assuming you're using NTSC or PAL).
Colour space conversion is a matrix transform using the following matrix:
(Y ) = ( 0.299 , 0.587 , 0.114 , 0.0 ) (R) (Cb) ( -0.147 , -0.289 , 0.436 , 128.0 ).(G) (Cr) ( 0.615 , -0.515 , -0.1 , 128.0)) (B) (1)
Ok, I must be missing something. I have YCbCr data in RAM that is 8bit grey scale. If I have YCbCr grey scale how would I colorize it I guess is the question. My output goes to an encoder that outputs NTSC analog.
For NTSC, YCbCr is not trivial to colour as it is. It will usually be running with Y interleaved with alternating Cb and Cr. This is because the human eye only needs half of the colour information compared to luminance, so you get the following data stream:
Y0 Cb0 Y1 Cr0 Y2 Cb1 Y3 Cr1 etc.
This makes it very hard to colourise a 422 data stream. Its much easier to think in terms of RGB and then colour space convert it to 444 YCbCr then do the data rate conversion to make it 422 (you just take adjacent CB/Cr values and divide them by 2).
see this article on wikipedia:
http://en.wikipedia.org/wiki/ycbcr
Basically, its not simple to do.
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
I understand you are trying to beautify the grey-scale image.
A way to do this is to traverse one of the six sides of the rgb colour cube (http://http://www.mathworks.com/help/toolbox/images/color7.gif). E.g. to get images form dark-blue for grey-value 0, to fiery-red for grey-value 255, you could use the following formula:
R <= grey_value ;
B <= 255 - grey_value ;
G <= 0 ;
Or traverse the colour cube from blue to yellow: start from R=0,B=255,G=0 for grey-value 0 towards R=255,B=0,R=255 for grey-value 255.
Of course you can think of other variations ...
