Hi there,
I am working with a CPRI_IP v11.1 in Quartus II 11.1 SP1. I have a working master (REC) configured CPRI block and I am currently working on the slave end. The signals I used while working on the Master block were: reconfig_togxb_m[3:0] reconfig_fromgxb_m[16:0] reconfig_clk reconfig_busy which easily port map to the ALTGX_RECONFIG megawizard block which has the same signals: reconfig_togxb_m[3:0] reconfig_fromgxb_m[16:0] reconfig_clk reconfig_busy But now that I am working with RE configured CPRI block, the signals I need to deal with are: reconfig_togxb_s_tx[3:0] reconfig_togxb_s_rx[3:0] reconfig_fromgxb_s_tx[16:0] reconfig_fromgxb_s_rx[16:0] reconfig_busy reconfig_clk Whats the best way to implement ALTGX_RECONFIG block in a slave mode. Do I need to have 2 reconfig blocks? Any help will be great thanks. SharmaLink Copied
