FPGA Intellectual Property
6660 Discussions
altsyncram simulating, data changes on failing edge
I'm simulating altsyncram with Modelsim for Cyclone V.
I use altsyncram instantiated as ROM.
INCLUDE "altsyncram.inc"; FUNCTION mROM_256x18_1port( clock, address ) returns( q ); PARAMETERS ( FILE_MIF = "FILE.MIF" ); SUBDESIGN mROM_256x18_1port ( address : INPUT; clock : INPUT; q : OUTPUT; ) VARIABLE altsyncram_component : altsyncram WITH ( ADDRESS_ACLR_A = "NONE", CLOCK_ENABLE_INPUT_A = "BYPASS", CLOCK_ENABLE_OUTPUT_A = "BYPASS", INIT_FILE = FILE_MIF, INTENDED_DEVICE_FAMILY = "Cyclone V", LPM_HINT = "ENABLE_RUNTIME_MOD=NO", LPM_TYPE = "altsyncram", NUMWORDS_A = 256, OPERATION_MODE = "ROM", OUTDATA_ACLR_A = "NONE", OUTDATA_REG_A = "UNREGISTERED", WIDTHAD_A = 8, WIDTH_A = 18, WIDTH_BYTEENA_A = 1 ); BEGIN q = altsyncram_component.q_a; altsyncram_component.clock0 = clock; altsyncram_component.address_a = address; END;
I've create simple project for testing the ROM only.
Simple SystemVerilog file to compile parametrized ROM to SystemVerilog netlist to simulate with Modelsim:
module ROM_Coeff_AHDL(address, data_out, clock ); input wire address; output reg data_out; input wire clock; mROM_256x18_1port# ( .FILE_MIF ("filt_triangle.mif") ) inst_mROM_256x18_1port ( .clock (clock), .address (address), .q (data_out) ); endmodule
Testbench. Incrementing address with every clock rising edge:
`timescale 1 ps/ 1 ps module memory_short_tb(); wire address; wire data_out; reg clk; reg addr_counter; ROM_Coeff_AHDL U_memory( .address (address), .data_out (data_out), .clock (clk) ); initial begin clk = 0; addr_counter = 0; end always# 1 clk = ~clk; always @ (posedge clk) begin addr_counter++; end // always assign address = addr_counter; endmodule
And the result :
http://www.alteraforum.com/forum/attachment.php?attachmentid=12140&stc=1
Data changes on failing edge.
But the datasheet https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_ram_rom.pdf says "Rising clock edges" on the page 3-2 .
Why data changes on failing edge? Has anybody get the same issue? What is wrong? How to fix issue?
the DSP Builder Advanced Blockset's Handbook mentioned an example of FFT known as "parallel floating-point fft" and has as a model file "demo_parallel_fpfft.mdl
and a second one named Variable-Size Floating-Point FFT,[/B] its model file is demo_fpvfft.mdl.
Could anyone give me an explanation of what these designs examples demonstrate ?[/B]
After changing
to
always# 10 clk = ~clk;
Data bus updates 1 ps after rising edge of clock.
