FPGA Intellectual Property
6262 Discussions
can SGDMA be controlled by FPGA logic?
Dear all,
Can SGDMA be controlled by FPGA logic without any C program from Nios II if we only use it to transfer data between on-chip memory and off-chip memory (DDR2 SDRAM)?
If so, how to do that more easier and efficient? What steps need be done? Anyone has examples/documents?
Thank you very much!
You can.
NIOS does not have a special role, it's just yet another Avalon-MM master.
You can use whatever you want to control SGDMA. All you need is to make your logic an Avalon-MM master which writes the proper values into the SGDMA configuration registers.
So, basically, we're talking about a some kind of state machine.
That said, slapping in NIOS II/e core and a small C program should be simpler.
I agree, it's possible but processors are normally more appropriate for control plane type stuff like this.
