I found this fourm and altera website,and I din't found any example about SDI Audio IP Cores,such as:
1.SDI Audio Embed MegaCore Function 2.SDI Audio Extract MegaCore Function 3.Clocked Audio Input MegaCore Function 4.Clocked Audio Output MegaCore Function If you have an example ,can you share with me?Thanks verymuch. Best regards.Link Copied
the same i am looking for .....
Not going to help you in a positive way, but you might want to refer to:
http://www.altera.com/literature/rn/rn_ip.pdf page 324 etc. The implication is it doesn't work very well. And having tried to use it the ug_sdi.pdf is very very limited in its documentation. Cheers, Simon- Mark as New
--- Quote Start --- Not going to help you in a positive way, but you might want to refer to: http://www.altera.com/literature/rn/rn_ip.pdf page 324 etc. Cheers, Simon --- Quote End --- File rn_ip.pdf ( MegaCore IP Library Release Notes and Errata ) doesn't have page 324.
--- Quote Start --- File rn_ip.pdf ( MegaCore IP Library Release Notes and Errata ) doesn't have page 324. --- Quote End --- That's because the release notes get updated with each release of Quartus. So my comment and the page number would only be relevant for the version I was using at the time. Probably v11.0.
What document are you referring to at page 324?
--- Quote Start --- What document are you referring to at page 324? --- Quote End --- Try this one: http://www.altera.com/literature/rn/archives/rn_ip_110.pdf But if you are using a later version then at least compare with the later release notes to see if they've fixed everything.
The structure of December 2012 version of rn_ip.pdf is different, thats why it has smaller number of pages - 56 vs. 650 ( !!! ) in previous version.
For every Errata it has the same text: for the most recent list of errata for the function, refer to theknowledge base page of the altera website. also, you can use the knowledge base to
search for errata based on the product version affected and other criteria.
So, now You never know - if Errata List grows or not.:cool:
--- Quote Start --- I found this fourm and altera website,and I din't found any example about SDI Audio IP Cores,such as: 1.SDI Audio Embed MegaCore Function 2.SDI Audio Extract MegaCore Function 3.Clocked Audio Input MegaCore Function 4.Clocked Audio Output MegaCore Function If you have an example ,can you share with me?Thanks verymuch. Best regards. --- Quote End --- I am also lookig for it...
