FPGA Intellectual Property
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
5791 Discussions
changing endian in Avalon FIFO Memory
ASuba
Hello
I am using Avalon FIFO memory with inout to AVALONMM_Memory mapped interface and Output conencted to AVALONST_Source. I find that the 32 bit days entering Memory mapped input is reversed bytewise with High endian converisona t output side.
1) Why is this so ?
2) Is there a possibility to change the behaviour and get the data as we send through the input side ?
-Athi
GuaBin_N_Intel
This is because by default, avalon FIFO's streaming interface has the properties "firstSymbolInHighOrderBits" set to be true. You can check it in Qsys>System contents by clicking on the streaming output. When it is true, data[31:24] will become D0 in data streaming https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf, Table 18. You could not change it as it is predefined setting in the IP. What you can do is to reverse the data symbol at output of Avalon-mm FIFO.
