Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
clocked video input , output
In my design I try to simulate input video on fpga
in the begin I connect test pattern to the output video and it work good
then I generate test pattern and out with embbeded sync and connect it (out from qsys)
to video input with embbede sync inside the qsys and output the signal to DVI monitor
test pattern - > video out -> video input -> video out
this link work good
right now I try to connect the middle video out to video input but I change them to separate wire and the video don't work
someone have an idea?
here is the connection outside the qsys between input and output signals
alt_vip_itc_4_clocked_video_vid_clk => clk_148_5mhz,
alt_vip_itc_4_clocked_video_vid_data => ycbcr,
-- alt_vip_itc_4_clocked_video_underflow => alt_vip_itc_4_clocked_video_underflow,
alt_vip_itc_4_clocked_video_vid_datavalid => alt_vip_itc_4_clocked_video_vid_datavalid,
alt_vip_itc_4_clocked_video_vid_v_sync => alt_vip_itc_4_clocked_video_vid_v_sync,
alt_vip_itc_4_clocked_video_vid_h_sync => alt_vip_itc_4_clocked_video_vid_h_sync,
-- alt_vip_itc_4_clocked_video_vid_f => alt_vip_itc_4_clocked_video_vid_f,
alt_vip_cti_0_clocked_video_vid_clk => clk_148_5mhz,
alt_vip_cti_0_clocked_video_vid_data => ycbcr,
-- alt_vip_cti_0_clocked_video_overflow => alt_vip_itc_4_clocked_video_underflow,
alt_vip_cti_0_clocked_video_vid_datavalid => alt_vip_itc_4_clocked_video_vid_datavalid,
alt_vip_cti_0_clocked_video_vid_locked => alt_vip_cti_0_clocked_video_vid_locked,
alt_vip_cti_0_clocked_video_vid_v_sync => alt_vip_itc_4_clocked_video_vid_v_sync,
alt_vip_cti_0_clocked_video_vid_h_sync => alt_vip_itc_4_clocked_video_vid_h_sync,
alt_vip_cti_0_clocked_video_vid_f => '0'
inv the clock
