In my design I try to simulate input video on fpga in the begin I connect test pattern to the output video and it work good then I generate test pattern and out with embbeded sync and connect it (out from qsys) to video input with embbede sync inside the qsys and output the signal to DVI monitor test pattern - > video out -> video input -> video out this link work good right now I try to connect the middle video out to video input but I change them to separate wire and the video don't work someone have an idea? here is the connection outside the qsys between input and output signals alt_vip_itc_4_clocked_video_vid_clk => clk_148_5mhz, alt_vip_itc_4_clocked_video_vid_data => ycbcr, -- alt_vip_itc_4_clocked_video_underflow => alt_vip_itc_4_clocked_video_underflow, alt_vip_itc_4_clocked_video_vid_datavalid => alt_vip_itc_4_clocked_video_vid_datavalid, alt_vip_itc_4_clocked_video_vid_v_sync => alt_vip_itc_4_clocked_video_vid_v_sync, alt_vip_itc_4_clocked_video_vid_h_sync => alt_vip_itc_4_clocked_video_vid_h_sync, -- alt_vip_itc_4_clocked_video_vid_f => alt_vip_itc_4_clocked_video_vid_f, alt_vip_cti_0_clocked_video_vid_clk => clk_148_5mhz, alt_vip_cti_0_clocked_video_vid_data => ycbcr, -- alt_vip_cti_0_clocked_video_overflow => alt_vip_itc_4_clocked_video_underflow, alt_vip_cti_0_clocked_video_vid_datavalid => alt_vip_itc_4_clocked_video_vid_datavalid, alt_vip_cti_0_clocked_video_vid_locked => alt_vip_cti_0_clocked_video_vid_locked, alt_vip_cti_0_clocked_video_vid_v_sync => alt_vip_itc_4_clocked_video_vid_v_sync, alt_vip_cti_0_clocked_video_vid_h_sync => alt_vip_itc_4_clocked_video_vid_h_sync, alt_vip_cti_0_clocked_video_vid_f => '0'Link Copied
inv the clock
Topic Options
