FPGA Intellectual Property
cyclone xcvr 10g phy
mengyaozhu
测试cyclone10  10G transerver phy ip时,10gbase-r
求解:
 tx_parallel_data 信号,fb控制信号可以在64bit 任意byte位置上么 ,仿真时  只能在tx_control=01的
 字节位置上。
ZiYing_Intel
Can share your .qar file here? So that I can try debug the issue from my side.
zying
ZiYing_Intel
zying
ZiYing_Intel
For your information, the width of tx_parallel_data and tx_control depends on whether the simplified interface is enabled or not. If the simplified interface is enabled, then tx_parallel_data = 64 bits and tx_control = 3 bits. The value 2'b01 indicates a data word and the value 2'b10 indicates a control word.
zying
ZiYing_Intel
Since no hear any feedback from you, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue.
zying
