input spi_data_i;
output reg spi_data_o;
reg [15:0]shift_sender;
reg [15:0]shift_receiver;
code 1: spi receiving code=========================================================
always @(posedge spi_clk_50M or negedge spi_rst_n)
begin
if(~spi_rst_n)
shift_receiver <= 16'h0;
else
shift_receiver <= {shift_receiver[14:0],spi_data_i};
end
code2 :spi sending code ============================================================
begin
if(~spi_rst_n)
begin
shift_sender <= 16'h0;
spi_data_o <= 1'b0;
end
else
begin
spi_data_o <= shift_sender[15];
shift_sender <= {shift_sender[14:0],1'b0};
end
end
I am implemented a spi interface which clock is 50Mhz shown above, the sending code work correctly,but the receiving code can not receive any data using verilog to implement the shifting in register?
I have implemented a uart interface which clock fequency is 1Mhz using the simliar code above,the receiver and sender all work correctly;
do the LPM_SHIFTREG must be used in the serical receiving code when the clock fequency is too fast such as 50Mhz?why ?
May I know which device you are using? It is mentioned that the receiving code cannot receive any data using Verilog to implement the shifting in register? Could you explain in details and provide error message (if any). Do you check the simulation result and sdc constraints?
May I know if you have any updates?
