what we need is the MAC+PHY whole ref design
10GE(1GE/10GE MAC) and 1GE/10GE multi-rate ethernet phy example design
just like Figure 5. Architecture of 2.5G, 1G/2.5G, 10M/100M/1G/2.5G, 1G/2.5G/10G, 10M/100M/1G/2.5G/10G (MGBASE-T) Configuration
in document 1/2.5/100G Multi-rate Ethernet PHY Intel® Stratix® 10 FPGA IP User Guide
HI,
The reference design can be generated insides low latency 10G MAC IP directly. The reference design will contains both MAC + PHY IP together.
You can also refer to below design example doc as reference.
dlim
HI,
The reference design is mostly build up based on Multirate PHY IP. It may switch more than just 1G <=> 10G.
For example, you can refer to chapter 3 (page 22) or chapter 5 (page 43) reference design.
dlim
HI,
I hope I have clarified your doubt.
For now, I am setting this case to closure.
dlim
